- 27 Aug 2008
So I finally managed to save up enough money to upgrade from my trusty Q9550. All the kit arrived on Saturday (thanks OCUK) and I got everything assembled by Sunday afternoon.
At first everything seemed OK. I got the RAID set up and installed Win7 with no problems.
When I opened the side of the case to check if everything was OK I noticed 2 problems.
1. I am using 2 x 2TB WD Black HDs and they are both too hot to touch. I had 1TB Blacks in my old PC and they are only warm. How can I tell if these are faulty? I can understand one of them being dodgy but they both do exactly the same thing.
2. My Corsair H100 cooler sounds like an old hard drive chattering away. The noise gets quieter if you put the case on it's side but it never goes away. I left it running all afternoon yesterday and it isn't getting any better.
Any suggestions? Will the H100 get better? Are my HDs too hot?
I hate RMA'ing things because of the hassle and postage expense. Do I send the H100 back to OCUK or Corsair?
Thanks in advance.
Thanks in advance.
