- 24 Nov 2012
Hey, not long set up my first every system but there appears to be a couple of problems. The first(1) of which is that the system does not seem to pick up on my HDD, although it does pick up on my SSD (where I have just installed windows).
The HDD and SDD are wired the same, the only thing i can think of is that the SATA power cable have multiple SATA power attachments (the long L) so I've used a single power cable to connect both the SDD and HDD to the psu. I was only provided with 2 of this SATA power cords and the only connects the DVD/RW to the psu so I has to use one to make 2 connection and it appears to have that facility as part of the cable.
This is the HDD ive used: http://www.overclockers.co.uk/showproduct.php?prodid=HD-025-TS
The next problem (2) which I feel might just come down to my inexperience, is that I have installed the gpu and used the software provided to install the drivers (not yet updated due to lack of lengthy ethernet which i will sort today) after which there was a reboot.
The problem is I see no increase in graphics quality - by the looks of things its still running from the inbuilt mobo gpu - and when i do windows test centre thingy - it gives me a 1 rating for graphics. I am running with the gpu connected to my TV, there is a VGA adapter included in the gpu case (7850 btw) which i plug into the longer port on my gpu (not the hdmi one - not sure of the name!) and connect my vga into that and into the TV.
Not sure if i'm doing something wrong here
Thanks for the help!
