Hi,
I am buying a new PC on tuesday this week and have a couple of questions.
My CPU has been picked:
HDZ550WFGIBOX - AMD Phenom II X2 550 Black Edition, Callisto, S AM3, 3.1GHz, 7MB Total Cache HT 4000MHz, 85W, Retail
I am not counting on this CPU to be unlockable to an X3 or X4, but i would like to get a motherboard that will at least allow me to have a try. However, as a standard X2 the CPU is still the best i can afford and for the right money, so its fine if it doesnt unlock.
That said, which of the motherboards have the ACC option to allow fettling with the CPU?
The mobo has to be £100 ish.
so, one of the below.
Biostar TA790GX A3+, AMD 790GX, AM3, PCI-E 2.0, DDR3 1333, SATA 3Gb/s, SATA RAID, ATX, On Board VGA
Gigabyte GA-MA790XT-UD4P, AMD 790X, AM3, PCI-E 2.0 (x16), DDR3 1666(OC), SATA 3Gb/s, SATA RAID, ATX
Asus M4A78T-E, AMD 790GX, AM3, PCI-E 2.0 (x16), DDR3 1600(OC), 1333, SATA II, SATA RAID, ATX, VGA
http://forums.overclockers.co.uk/Pr...-DDR3-1600(OC)-1333-SATA-II-SATA-RAID-ATX-VGA
Then my next question is, do i go for DDR2 or DDR3?
I want 2 x 2GB for £60ish
My options are:
DDR2 1066MHZ @ CAS 5 ie Corsair Dominator or TwinX
DDR3 1333MHZ @ CAS 9 ie Corsair TwinX
DDR3 1600MHZ @ CAS 9 ie Corsair Dominator or TwinX
In terms of overclocking and messing about with stuff, i dont really want to mess about too much. I just want to leave it all alone apart from attempt to enable the 4 cores, and OC the CPU to 3.6 - 3.8Ghz on a stock cooler. Thatll do me. So if DDR2 is faster than DDR3 as standard then thats what ill get.
Any advice appreicated.
Gaz
My options are:
Gaz
