Hi their im going to do a water cooling rig soon when the Corsair 900D comes out and im wanting to seriously water-cool it.
so far my water cooling set up will include
Radiators:
480 mm (top)
480 mm (bottom left side)
360 mm (front)
240 mm (bottom right side)
maybe 120 mm (back)
W/C components:
water cooled Asus Rampage IV Extreme
4x 2 piece ram cooling blocks
cpu
2x gpu in serial flow
res/d5 pump combo
i know its overkill but i want a full water cooled rig
questions:
1.In which order would you make the water flow,i was thinking res/pump,ram,ram,cpu,ram,ram,420 rad,120 rad,gpu,gpu,420 rad,240 rad,360 rad,then back to res/pump nut im not sure if that will be the best way.
2.Would a d5 pump be powerful enough to pump all this water
3.Is it too much for a single loop?
Any questions are appreciated
thanks
Josh
Radiators:
480 mm (top)
360 mm (front)
maybe 120 mm (back)
W/C components:
cpu
res/d5 pump combo
questions:
thanks
Josh
