I've got a spare PC with some identical componants to mine, and I want to add the hard drive and cd drive to my current PC. Both of these are the same as my current HDD and CD drive. Two questions:
1. If I want to delete everything on the new hard drive, should I format it on the BIOS screen or right click on the drive in "My Computer" and click format, or doesn't it matter? And should the pin configuration be set to slave on this? Will the drive be plug and play once a new partition is added?
2. Should the pin configuration be set to master on the main CD drive and Slave on the 2nd? There is also a CS option which I am unsure of what it is for, can somebody explain this?
Thanks
Thanks
