- 18 Jan 2011
- A remote car park
I have a couple questions which will probably seem dumb to you guy`s lol
1. When in the BIOS (Gigabyte) does the CPU run @ 100%?
Reason i ask is i have been having fan/noise problems and decided to go in and have a look.
All my voltages are a touch on the high side
Normal VCORE should be 1.400V but BIOS reports VCORE 1.465V (same as HWMonitor)
DDR should be 1.5V but is showing as almost 1.6V
This is only stock, no overclocking/overvolting etc
Are these anything to be concerned with?
2. i noticed i can undervolt my VCORE (but not my DDR only overvolt)
i dropped the VCORE by 0.025V and now its running at 1.37V
Windows booted fine, is it OK to undervolt like this?
I noticed a slight drop in temps too which is a result (2 degrees idle) but will this cause stability problems?
Sorry for what are probably dumb questions. not exactly experienced with tweaking voltages, just FSB for my OC`s in the past.
I am not aiming to OC atm anyway. just curious regarding my 2 questions
