cover them cables! - advise
5 Jun 2005
Southampton
hello,
my front room has had a rejig and although it looks a bit more spacey now i have two walls with cables run along the ground, i have semi tacked them, but thinking of getting a small bit of trunking or cover, its only a network cable and 2 think speaker wires but, looks a bit unsightly.
anyone recommend a brand, or place to get these?
I got these from B&Q:
http://www.diy.com/nav/fix/electrical/cable-accessories-management/cable-management/trunking/D-line-Self-Adhesive-Micro-Trunking-White-Pack-Of-4-9726456
Did a run above the skirting around half the room including over a door and it did the job fine. Looks like an extension of the skirting so you don't even notice it.
It is VERY small though so if they're fat speaker cables you may struggle. They do them in different sizes though so have a look first. They even do corner/joining pieces as well but these didn't fit together that well.
