Covering up pc case mesh?
I was thinking of covering mine as it used to be the same, but I changed the fans around and fitted a 140mm fan at the front for positive pressure in the case so it blows air out the mesh rather than suck it in, stays very clean now :)
On the side of my Antec 300 I have no fan, so I cut out an A4 sleeve and taped it over the hole on the inside of the case.
Looks a bit poo but is a cheap fix.
I did a very similar thing, with a sheet of a4, but every time i look at it... it looks like a turd.
I'm thinking a sheet of acrylic attached from the inside with double sided tape. But i can't seem to find any shops that have acrylic in my town.
