if you take the coving down it will almost certainly make a mess of the walls meaning even more plastering to do, I'm assuming it is modern stuff and nothing decorative/period if it is then don't touch it! Personally I'd ask the plasterer!
We had a quick skim of the ceilings done with the coving in place. It looks OK, better than I was expecting.
I assume you've got artex swirls or something up on the ceiling at the moment? If so they'll knock all that back with a blade/scraper and then skim on top tapering in to meet the coving edge. You'll lose a bit of the edge height, but done properly it'll look decent.
Once it's dry, misted and given a couple of coats of emulsion you'll probably never be able to tell.
