- 14 Jul 2005
- Bristol
I'm using an AMD Athlon 300+ skt 754 64bit CPU at 2.4GHz, 1.25GB RAM and a GeForce 6200 128MB graphics card.
When I run videos (or try to) my CPU maxes out to 100% and the videos won't run, MediaPlayer, JetAudio and all other players just say 'connecting'. The task manager says that it's not the video player maxing out, and it normaly says it's explorer (sometimes it doesn't say anything is, even though it is maxing out).
I have re-installed windows (running Windows XP Home) twice now. Videos were working but I re-installed the PC for other reasons, then I started to get this video problem, so re-installed windows, and I am still getting it.
I've had someone tell me that he had this problem, and it was due to windows not loading the videos correctly into the RAM...and he fixed it by re-installing.
This is really trying my patience as I do video editing and need to be able to play videos.
If anybody has any idea as to what is wrong and how I can fix it (ideally without yet another re-install) that'd be great.
Cheers.
InvG
Cheers.
InvG
