CPU 12v 8 pin 180 degree adapters.
31 Oct 2006
Uttoxeter
Hey,
Does anyone know where I can find some of these? Can only see some dodgy Chinese things on Amazon so wondered if there were some more 'premium' options.
Also need a 8 pin pcie 180 degree adapter and 24pin (but 24pin is easy to find)
Thanks
Don't think there's any 8 pin eps 180 for the CPU just pcie 8 pin.
EZDIY-FAB do 24 pin 180 as well as 8 pin pcie
Never seen a 180 degree EPS only 90 degree ones however there is another alternative if you don't mind de-pinning your cable plugs. I have done exactly that on my motherboard 24 pin and 8 pin EPS cables. I also have a set of pci-e cables done but in the gpu's current config they wouldn't fit so I made my own cables for that instead. You can get just about any cable variation there is for a pc and they come in clear, black and white colours. I got mine from a seller on Ebay but he's not around anymore but I did find someeone else selling them called MacroMods. They are like a double cable comb and I think the finished cable looks much neater than these adaptors you can get. Here are a couple of pictures:-
These images are from my previous build showing 6 and 8 pin pci-e, 24 pin ATX and 8 pin EPS cables all done.
They are not very expensive, the 8 pin ones are £2.25 and the 24 pin only £2.65. You do need a bit of patience and time to fit them though.
