Wonder if you can help this afternoon I installed a m5a99fx and a Corsair Hydro H60 V2 High Performance Liquid CPU.
Im new to this mobo and I hope this is the correct place to post this thread! Basically on picking the Asus optimal settings rather than power saving or normal It pushed my CPU speed uptoo around 4373 rather than 4. However it did lower my ram speed too 1151 which I found odd, I have done into the setting and set this to manual and i could only pick 1728mhz which is fine slightly over clocked, Restarted and booted too Speed 4370mhz and DDR3 1728mhz.
However when I look at my task manager im seeing this.. Any ideas?
https://imageshack.com/i/mwtjdbj
Also when I click on memory the speed is only saying 1600MHz
I have power saving off in mobo options.
Thanks
Thanks
