This is an odd one, my GPU on idle sits at a whopping 75-78'c and de-clocks itself when I try and use games.
Now, this really doesn't make sence as the case has two 120mm fans keepin it below 30'c and the CPU is overclocked to 2.5GHz from 1.8 (opty) and doesn't pass 40'c under load yet the GPU is cooking all the time!
I checked the seating of the fan on the 6800 Ultra and its fine and obviously the fan is spinning away as it should.
Any suggestions, its very odd.![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
