- 21 Mar 2007
The PSU I'm using for my build is a Corsair RM650. The back panel has (other than the usual SATA/ATX slots) three identical-looking slots and simply labelled "6+2 PCI-E & 4+4 CPU". There's an image here if my description is a bit useless!
Am I correct in thinking that these three are interchangeable? I assume from the label that they should be, but I'm aware that if they aren't interchangeable it would be a Very Bad Thing to plug the CPU power cable into what the PSU intends as a GPU slot, or vice-versa!
