Okay, rather like my system drive choice I'm stuck with a cpu conundrum too lol.
I have a choice between the following:
Intel® Core™ 2 Quad Q8200 2.33GHz 4MB Cache 1333MHz FSB
Intel® Core™ 2 Quad Q9400 2.66GHz 6MB Cache 1333MHz FSB
Intel® Core™ 2 Quad Q9550 2.83GHz 12MB Cache 1333MHz FSB
Intel® Core™ 2 Quad Q9650 3.0GHz 12MB Cache 1333MHz FSB
or going for the
Intel® Core™ 2 Extreme QX9650 3.0GHz 12MB Cache 1333MHz FSB
and I'm not sure if I should stick with the cheaper Quad Core option or spend the extra now on the Extreme 9650 to save performance issues in the future.
Right now the rig would be used for gaming, using MMORPGs and 3D environments, graphic design work as well as regular HTPC use, all with a fair bit of multitasking - I've never been much good at doing one thing at a time so am usually in a MMORPG, working in photoshop, browsing forums and web pages plus having a cigarette all at once lol. The system would be on and in use for long periods of time during the day, so I don't know how that would effect the performance of any of these CPUs.
Can anyone give me some advice as to what would be the best way to go? What I don't want to happen is to cut a corner now only to find out it'll need upgrading sooner rather than later, but at the same time I don't want to waste money on something that isn't suited to me. I am looking for a high-end gaming machine that will handle a lot of use and high graphics whilst still giving me the speed and stability I need. If that makes sense! Is sticking with the Quad Core the best for me or would looking at the new i7 be better suited? I'm really not sure so I'm open to suggestions!!
or going for the
