system i run
amd 6000+
3 gig ddr2 800mhz
gtx 260 Nividia
Abit AX78 MB Socket AM2
750w psu
Vista 32bit
No PC Parts are Overclocked
Wanting some advice on AMD CPUs as i have a Tempature Problem at the moment i have a good Heatsink and fan and have used many types of thermal paste to lower the Tempature of the CPU with no luck as of yet .
Using Speedfan 4.32 system Tempatures Read like this When not Running anyhing Underload
system 42C
CPU 54C
AUX 58C
Core 49C
Running a game Tempatures like this
System 48C max
CPU 66C max
AUX 68C max
Core 58C max
The Room with my PC in is like 10c over the Tempature of outside you see and ill never run any CPU cool that i understand this CPU is at stock speed not overclocked at all.
iam Wanting to upgrade to Quad Core but needed Advice on ie like would Quad Core Run Hotter than the Temapures iam getting at the moment with this AMD 6000+ CPU and should i look for a CPU of Less Performance but Lower Tempature seems wrong to down grade my CPU for a Cooler CPU low Performance.
Thx
amd 6000+
3 gig ddr2 800mhz
gtx 260 Nividia
750w psu
Vista 32bit
system 42C
CPU 54C
AUX 58C
Core 49C
System 48C max
CPU 66C max
AUX 68C max
Core 58C max
Thx
