CPU Advice
TC1
TC1
Permabanned
10 Jan 2007
What is the difference between the AMD 'Venice' and 'Manchester' chips? Seen a cheap:
AMD (MANCHESTER) Athlon 64 3500+ Socket 939 2.2GHz 512kb Retail Boxed Processor
Only need a bog standard one for a friend. He has a socket 939 Motherboard.
Will the above be ok?
Small possibility he needs a BIOS update, had problems with boards not booting with Winchester or Venice chips without a BIOS update as their BIOSes were fairly old.
TC1 said:
So, no such chip as a 'Manchester one'?
Who said that? I just meant that he might need a BIOS update to get it booting, of course you need an older core to do that, the Manchester is newer than the Newcastle, Winchester and Venice so theres a small possibility depending on the board BIOS that it may not boot the chip. Yes theres a 3500+ Manchester chip.
Manchesters are dual core 512KB cache (each core).
I believe some of them did appear as single core chips, presumably becuase one of the cores was faulty from manufacter.
Jokester
Jokester
Seems far fetched.
I have the chance of swapping my venice 3500 for a Manchester 3500. What are the differences? Is one better than the other?
