Does the rendering have long waits with all cores pegged at 100%?All i use it for is for gaming and rendering 3D Prints.
Im using a 4070ti super pro art and i only play in 1440What graphics card do you have and what resolution do you play at?
I'm asking those questions because if you're not careful, you'll notice nothing except a lighter wallet.
agreed.I'm asking those questions because if you're not careful, you'll notice nothing except a lighter wallet.
is this program heavily multithreaded?rendering 3D Prints
the program isnt very demanding tbh, budget wise im happy to pay any cost as it'll be a uprdade to last me a whileagreed.
what is your budget?
i was looking at these cpu but still very undeciedi would sugest a 9800x3d or a 9950x3d, then can look at a gpu upgrade in the future and not have to worry about a possible cpu upgrade too![]()
honestly if you're fine with the current performance of your 7700+4070 ti super, i'd be inclined to leave it alone tbh (why wouldn't you be, it's an extremely competent setup)the program isnt very demanding tbh, budget wise im happy to pay any cost as it'll be a uprdade to last me a while
7950x for ~£400, 16 cores and a good boost clock. Could even run it in ECO mode for a big drop in power/heat.i was looking at these cpu but still very undecied
im planning to swap to full watercooled next year so might be worth holding out till then?honestly if you're fine with the current performance of your 7700+4070 ti super, i'd be inclined to leave it alone tbh (why wouldn't you be, it's an extremely competent setup)
you'd probably be better off skipping this generation and then getting the 10800x3d or whatever AMD decides to call their next AM5 chip
the reason being, that will be the last AM5 x3d chip (as far as we are aware), and then no more upgrades after...so, that will be the end-game for AM5, and will be the upgrade that gives you the biggest performance uplift
if you get the 9800x3d now, you'd still be leaving performance on the table for AM5, and the cost difference to upgrade from the 9800x3d to the 10800x3d may not be large enough to make financial sense
as in a custom watercooling loop? that's an even worse investment lolim planning to swap to full watercooled next year so might be worth holding out till then?
it’s more of a tax right off than a investmentas in a custom watercooling loop? that's an even worse investment lol
In that case, you need a 9950X3D.it’s more of aoopsthan a investment
thats what the tax man thinks tooIn that case, you need a 9950X3D.
Agreed. For tax purposes, definitely a 9950X3DIn that case, you need a 9950X3D.
I was tempted to do a spec like this, but I know there are lurkers that mine these threads for build ideas
My basket at OcUK:
- 1 x AMD Ryzen 9 9950X3D Sixteen Core 5.70GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-04501) = £699.95
- 1 x Asus ROG Crosshair X870E Hero (Socket AM5) DDR5 ATX Motherboard (SKU: MOT-ASU-03083) = £549.99
- 1 x Corsair Vengeance EXPO/XMP 96GB (2X48GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit (SKU: MEM-CRS-03746) = £269.99
- 1 x Crucial T705 2TB NVMe PCIe Gen5 M.2 Solid State Drive (SKU: STO-CRU-01870) = £186.95
- 1 x ASUS ROG Strix Helios Midi-Tower ARGB Gaming Case - Black Tempered Glass (SKU: CA-05B-AS) = £314.99
- 1 x Asus ROG Strix 1200w Platinum 80 Plus Platinum Power Supply (SKU: POW-ASU-03792) = £269.99
- 1 x ASUS ROG Ryuo III 360 Performance AIO CPU Liquid Cooler with OLED Display - 360mm (SKU: HS-05L-AS) = £249.94
Total: £2,541.80 (includes delivery: £0.00)
i was looking at that mobo and also picking up a rog 5090Agreed. For tax purposes, definitely a 9950X3D
In fact, i think Asus ROG is also calling!
