CPU and driver issue [after acronis]
Caporegime
13 Jan 2010
Llaneirwg
ive got a few driver issues after going backing up a HDD image of my system before raid, and recovering after raid
my sound no longer works, but interestingly i have the warning triangle on all 8 [4 + 4 HT] cores of my i7 920
i have never seen or hear of this before
ive found no obvious prolems with my system problems, but is there anything i should do i dont want something to go wrong down the line
try to uninstall all the cpu's in device manager that show the yellow triangle.restart and follow instructions on the screen.then reinstall your chipset drivers.hope this works for you
what will i be faced with if i uninstall the CPUs on reboot?
i had this for the sound device and uninstall/install worked, but i dont know what will happen if i uninstall the CPU drivers!!!
ok iill try that, i just didnt want to be left with an unusable system! cpu drivers arnt just some peripheral device lol
when i reinstalled the sound drivers all was normal with them... these were the only 2 things affected, which seemed weird
