Hi, I am going to build a mid range pc for 1440p gaming, coding and blender/other similar applications. I want a pc that can run games well in 1440p, and can create smooth animations even with complex meshes and builds that take a lot of rendering. Keeping budget in mind, should I go with the rx 7700xt and the r5 7600, or the 7800xt and the i5 12600k. I have heard that the r5 7600 is quite a bit better, so I’m wondering if the 7800xt is worth the price upgrade on the7700xt. So which pair should I go for? Or any other suggestion? Thanks
however, of course the i5 is a lot cheaper right now and would fit better into budget with the 7800xt, but the 7600 is a bit to expensive to pair With the 7800xt with my budget.
