CPU and HS Cleaner
27 Dec 2006
Hampshire
Im cleaning my HS and CPU (6300) and have some SWAN Lighter fluid for spot cleaning. However a little birdy tells me i could use lemon juice. Should I shoot the bird?
Alf
Alf
Wouldn't recommend it. Some of it will stick in the tiny creveces on the heat spreader. You need something that will evaporate fast. Lighter fluid might work, just dont set urself alight!
