Greetings,
I just installed an Akasa sink & fan to replace the stock AMD set that came with the AthlonXp 2000. I've already noticed a nice (10c) drop in temp on the cpu as according to the bios reading and using winbond hardware doctor that came bundled with the MB (Abit KD7A). WooHoo.
There's been a couple of "side effects" that I'm curious about though.
I've noticed that the NB temp has also reduced as well, about the same amount.
Also the bios detects cpu fan failure but the fan is obviously turning. I disabled the auto-shutdown and alarm (which stops as the OS boots up BTW) and the system seems stable (so far!).
Are these common side-effects or could there be a problem on the horizon?
Appreciate any input!![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
