So I have finally VERY NEARLY got all my bits together to start building my watercooling PC now. I decided to buy a Corsair 800d as it seemed a very nice case for watercooling (plus I liked the hot swapable drives, which ocuk are doing the 6Gb/s vers now
Anyways so my plan is to cool a i5 2500k and two 480GTX in SLI. I am thinking about rad sizes though. I thought about just getting a quad 480 I think it should fit into the bottom of the Corsair fairly nicely if not will mount it outside the case. Would a quad be ok though ? like this one 480 Quad rad
Or would I be better having a multi loop and have a 240 cooling the CPU then a 360 for the two Gfx cards ?
also on a side note with regards to my pump planning to get http://www.overclockers.co.uk/showproduct.php?prodid=WC-030-OE&groupid=962&catid=2141&subcat= will one of these fit into the bay type res's ok ? sounds like it might be pretty big.
Cheers
) Anyways so my plan is to cool a i5 2500k and two 480GTX in SLI. I am thinking about rad sizes though. I thought about just getting a quad 480 I think it should fit into the bottom of the Corsair fairly nicely if not will mount it outside the case. Would a quad be ok though ? like this one 480 Quad rad
Cheers
Also worth looking up for lots of water cooling component tests if you haven't already
