- 2 Nov 2009
- London
Hi all,
i have realised in all my wisdom i order the OEM verson of the i5 which means that i have no cooler!!!
not to worry though as i plan to upgrade my other pc (also i5) with a new cooler! and use the old cooler on the ohter i5 rig (if tht makes sense)
i have purchased the Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
now is it best to remove all thermal paste from the old CPU pefer installing the new cooler which has pre applied thermal paste?
like wise it is it best to remove all old thermal paste from the old cooler before installing it with the new I5??
hope thats not confusing !! i will try and summerise!
1. PC 1 is a new i5 chip that i am using an exsisiting old cooler on (should i remove all paste from cooler and start again)
2. PC 2 have a new cooler that im installing that has pre applied paste. (should i remove all exsisting paste from exsisting CPU?)
i plan to use Arctic Cooling MX-2 Thermal Compound and Akasa AK-TC TIM Clean CPU & Heatsink Cleaner to remove!!
thanks
thanks
