CPU Block for 1155, 3/4" OD Compression
26 Feb 2007
Leafy Cheshire
Hey dudes
Hit another delay on my build. My Heatkiller 3.0 wont allow me to use 3/4" OD Compression Fittings as the input and output holes are too close together.
Is there a CPU block you'd recommend that will DEFINITELY allow 3/4" OD Compression fittings?
That's not true, though, is it? I have G1/4 1/2"ID 3/4" OD compression fittings that dont both fit on my Heatkiller 3.0.
Skinnee to the rescue from http://skinneelabs.com/cpu-fitting-compatibility/2/
Oh, legend! That's awesome. I have generic compressions but i'll just match to bitspower for worst case scenario :)
Thanks dude!
