- 3 Oct 2011
- Hednesford, Staffs
Hi all, just starting to build my new rig and need a couple of answers.....I have a hunch that it wont really matter and may only make a degree or two difference for the whole loop but here goes:
1: I have a EK Supreme HF block (i5 2500k CPU), should I mount it so the holes are horizontal or vertical? Vertical means nicer tube routing but I am worried the block wont perform to its max capability.
Has anyone run the block that way or is it a big no no.
2: Last I had a GFX card in the loop I had two rads so choosing what componenets went where in the loop was easy, but I'm now building a loop with Vario d5, EK Supreme HF Block, EVGA GTX480 Hydro, XSPX RX360(maybe a res but not 100% on that yet)
What way should I be routing the tubing? Pump-CPU-Rad-GFX, Pump-Rad-CPU-GFX etc etc
