CPU bottleneck advise
18 Oct 2002
In my own little world
Hello
Recently checked my rig for bottleneck using MSI Afterburner with log and screen overlay.
In Cod WWII it shows CPU at 100% pretty much all the time, GPU jumps around 20% to 65%
I have settings mixed low-high and good FPS
I have noticed moments of game pause but not as much as may expect if CPU is really maxed out.
I can't check another game right now, my wow sub has expired and Blops4 is live so cant try the beta.
I am so out of touch I really don't know my best options.
Sig has rig right now, what CPU could I upgrade to on an economy budget.. not setting a limit but don't wont to spend more than necessary.
Thanks in advance for any advise.
Cheers
2d2f
Getting a 3770K and overclocking it would definitely help if you want to go cheap and second hand but if buying new then Ryzen 5 2600 is great value for what you get but that means upgrading mobo and ram.
Agree on both counts. well... unless you're wanting to switch to a newer platform away IMO the Ryzen rout is too costly.
Having said that a year ago i felt i couldn't put it off for much longer so i did change the whole platform from a 4690K, no regrets, and its done now, future upgrades simply means dropping in a new CPU and that's it.
Ryzen 2600 with decent mobo and 3200mhz ram will set you back £390. You should get about £140 for you current gear so a small outlay for a big upgrade.
I would think the faster of the two same Ram would have a higher chance of Samy B's, binning and all that. :)
wow, thanks for feedback.
If I wanted to just upgrade cpu with current rig, what would be best option.
I appreciate the new mobo/mem/cpu suggestions but was not thinking of a full rebuild right now, not ruling out but not first choice.
Not sure about comment to up the gfx settings, even if did that I still have a cpu issue? The settings are actually lower for Multiplayer play, easier for spotting and FPS genre (for me).
3770K, i think that's the best CPU you can get for the board :)
Although bottleneck calculator says the 3770 and 1060 are a good match it seems 3770 is old and difficult to get, and expensive still.
Seen some on auction sites but still get high price for used.
If I have to go down the rebuild road, what mobo/mem (16gb min)/CPU will be best combo to make most of my 1060 6gb?
Say £400 max?
I assume my PSU will be enough for anything newer.
Seen mixed comments on how good the bottleneck calculator site is so prefer the feedback here :)
Thanks
Say £400 max?
Thanks
https://www.overclockers.co.uk/msi-b450-tomahawk-socket-am4-ddr4-atx-motherboard-mb-33t-ms.html
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3af-am.html
https://www.overclockers.co.uk/team...-3600mhz-dual-channel-kit-blac-my-0a3-tg.html
Comes to £390
If overclocking you will need an after-market cooler, this one will do the job just fine for £22
https://www.overclockers.co.uk/alpenfohn-ben-nevis-cpu-cooler-120mm-hs-048-al.html
