I wan't to update an old HP m7530.uk pc with some new ram, psu and graphics, but if i were to put a 8800 or 9800GT in, i know / have been told it will not perform to its best with the old D 3.4GHz cpu and may bottleneck.
In what way will it effect the performance, surely in say Call of Duty 4 now with everything low and it still not hitting 125 fps it should after the upgrade and maybe a push up on some other things until the cpu is maxed out cuz it will get to the stage where the graphics run quicker than the cpu or something? :S
dunno
anyway theres
2GB (2x1GB) Corsair Value Select, DDR2 PC2-5300 (667), 240 Pin, Non-ECC Unbuffered, CAS 5-5-5-15
512MB HiS HD 3850 FullHD 1080p PCI-E 2.0, 1656MHz GDDR3, GPU 668MHz, 320 Cores, 2xDL DVI/HDTV, HDCP
and im not 100% sure on a psu as the one ive got now is a HIPRO 300W
dunno
anyway theres
