- 24 Jun 2003
Need some help to try to get my Bro's system working good with COD5 for the lowest budget as poss
Problem : everyone else has the new map loaded up and playing it for like near a min before he gets into the game,sometimes the game just goes black screen.
I got him to start task manager ,and the run the game,, it was using both cores ok,, and both were maxed to 100% but ram being used was low
I would have thought that the system would be up to the job. but maybee not ?
Motherboard : Asrock ALiveNF6G-GLAN
Cpu : amd athlon 64x2 4200+ socket am2(940)
Ram : pc2-5300 333mhz
Gfx card : powercolor ati hd 4870 1gb gddr5
Psu : Tagan 480W
Would a cpu upgrade fix the problem ..Is it a cse of CPU bottleneck ,, or should the above run it fine,,and is maybee some other issue ?
Psu : Tagan 480W
. Sounds like the reason he's taking so long to join is because he's running out of ram and the OS is having to cache loads of data into the pagefile, which if on the same hard drive as the game is installed will cause huge slowdowns.
