CPU bottleneck?
15 Oct 2003
Newcastle
My current rig is
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3)
XFX HD 5830 1GB - GDDR5 SDRAM
It's starting to struggle with newer games and I'm looking to start upgrading.
Ideally I'm thinking i5 4690k+mobo and a GTX 970 but I'm a bit strapped for cash at the minute.
If I was to just pick up the gfx card first would my current cpu be a bottleneck?
I have a q6600 and am looking at doing the same, upgrade the graphics now, and the rest when I can afford it. Sure, the card will be bottlenecked, but still a hell of a lot better than the 8800 GTX I have atm.
That's the advice I have got from these forums any how. Either that, or plump for a cheaper 2nd hand card with a view to upgrading that later too, but I think I would rather get a better one and keep it.
yes get the card is will be a lot better, the CPU is 100% going to gold it back but there will also be a massive improvement
but that said for 970 cash, you can get an i5 and motherboard
GPU will give you a huge increase in performance, a low end CPU can still power the big games as most of the work is done in the GPU as it's quicker.
is the CPU a black edition, and is your mother board upto over clocking.
what is your full set up.
mobo
cpu
ram
PSU
and so on
