- 21 Apr 2013
Hi! So basically I have had this problem for ages! In a lot of games I get a lot of stutters, every two minutes or so I get this tiny lag spike/stutter/freeze that lasts for no more than a second then my FPS shoots back up (sometimes I don't get it for a longer period). The main culprits are:
Arma 3
Miscreated
Rust
COD: Advanced Warfare
I really don't think it's the GPU as I've had two separate ones and the problem occurred with both.
My specs are :
GPU : HIS ICE-Q 7970
CPU: i5-3570k
RAM: 8GB
Windows 10
As I have ruled the GPU out, I believe it may by my CPU? But I'm just guessing as I have no real clue about these sorts of things!
Here is a picture of my CPU utilisation while playing Arma 3:
Is this normal? Nothing is overclocked and the CPU just has the stock cooler that came with it.
While playing Miscreated it got to 100% utilisation and noticed when it did the tiny second freeze it dropped to like 40%
I must say it doesn't happen on all games, when I play on Fifa, Black Ops 2 or H1Z1 I dont get any freezes, very smooth.
I thought about upgrading my GPU lately to a GTX 970 to try and get rid of this small stutter once and for all as it's really starting to frustrate me as I believe my PC specs are more than capable of doing a good job but it's not guaranteed that will fix it, as I said maybe it is actually a CPU problem?
Is anyone able to help me fix this problem once and for all?
Thanks!
Arma 3
Miscreated
Rust
My specs are :
CPU: i5-3570k
RAM: 8GB
Windows 10
Thanks!
