Cpu change
14 Apr 2011
Does anyone know or can tell me where to look to find out about a toshiba latellite pro l300-1ad processor. It has a Celeron 575 2.0ghz now,
Im looking to upgrade it but dont know what the fastest processor i could fit would be.
If you go to the toshiba laptop site and look up the satellite pro L300 there's email support option you can use. There's even a telephone number but this may be just be for sales.
I can't link to it as they sell products that are in direct competition to OCs - but you should get a pretty quick repsonse.
Upgrading the processor on a laptop isn't the easiest thing to do. In most cases the best way to upgrade is buy a better laptop :)
yeah there are some laptops that will take a cpu change quite easy but 97% of them wont...and i'd say for sure that you toshiba is one that wont..
Thanks for the response guys I have emailed them already awaiting reply. I was thinking it was a long shot by emailing them but they might give me an answer.
