Hi
I am looking to build a new PC.
I just have a question about the suitability of the processor, the choice being between the i5 or i7 and which model within those ranges.
I play a lot of a game whose client only utilises a single core of the processor, but it is quite CPU intensive, so the more power that core has the better. The turbo boost function would also help in this area.
The CPU of choice seems to be the i5-2500k which I believe can be clocked to about 4.2 using the built in automatic function.
So, my questions are:
From what I have read, the main advantage of the i7 over the i5 is the additional functionality of the hyperthreading/extra cores etc. There doesn’t appear to be any significant extra performance of the Cpu. So bearing in mind that the game I play most of, only uses one core, is it worth the extra cost ? If not, as the i5 chip has been around for a while, is it still the one to get ?
The i5-2500k seems to be a 2nd generation chip, while there are now 3rd generation i5’s (though different models) around for a similar price. Is there a comparable one of these, and would it give better performance?
Grateful for any answers and other advice you can give.
