- 27 Aug 2005
Hey, I’m going to replace my motherboard and heat sink fan. Is it necessary to remove the thermal component that is left over on the CPU with liquid cleaner?
Legend said:Make sure you don't leave any particles of cotton wool on your CPU when you clean it. That's why you should use a lint free cloth (a coffee filter would do) so that you don't leave tiny little particles behind that could affect performance.
w3bbo said:Q F T!
Same goes for tissue paper, kitchen roll, dusters and socks (yes someone has actually used a sock!).
dan7827 said:isopropyl alcohol swabs are what you want![]()
