cpu config help
16 Jan 2010
windows 7
asrock n61p-s 1.6 bios
amd x4 620 quad 2.6
hd 4670 512mb
2 g ram
I would like to overclock my cpu for light gaming. i have realised i should have got a different mobo but im afraid for now im stuck with this one. i have already received lots of help and was hoping someone could take the time to help me out.
1st of all i have no acc to enable in bios. i also cant unlock l3 cache even after going through every bios version.
I understand the basics of overclocking cpu was upping the multiplier and fsb. then slowly increasing voltage to make stable. my bios settings seem to be very limited. my multiplier seems to be set at x13 and my fsb at 200. my multiplier will not exceed x13, nor is there an option. i also see where i can change fsb, but once again this is locked even though it appears open. not looking good. my next plan was to use the oc tuner after checking compatibility. before i mess around with this though, i wanted to check my cpu config were correct in bios first.
1st question....my 1st option in cpu config is overclock mode. i have four options (auto), (optimised), (cpu pcie sync), or (cpu pcie async). no matter which one i choose i cant change fsb or pci frequency even though it appears unlocked. which setting should i use if im going to use oc tuner. i persumed optimised but need to ask the question.
Q2.. my 2nd option is Multiplier/Voltage change. i have to options manual or auto. blacked out it says....
cpu max freq. is x13 2600mhz
NB max frequency is x10 2000mhz
processor maximum voltage 1.4000v
NB goes from x1 to x10 . what should this be?
i can change processor voltage.... can i go over my maximum processor voltage even though blacked out is says my maximum is 1.4. when i choose manual i can change this in increnments of 0.250. i want the correct settings so i can use oc tuner to change things.
thanks in advance. i hope i,ve explained well enough.
your mobo instruction manual wilol highlight what each of these mean. Id suggest taking a flick through it or downloading one online.
