CPU cooler £20usg
18 Feb 2007
What cooler should I be looking for at about 20quid? Something thats pretty quiet but will keep cool temps for overclocking.
Cheers
Edit - Ignore usg in the title, made a typo :)
just reading the discription on the artic 7 and it says 3 pin conector but its a 4 pin one have they changed it,as would like one to connect srtaight to my fan control and need 3 pin connectors not 4 cheers
Xigmatek S1283
The 1283 isn't £20 though, it's closer to £30.
For £20 you're looking at the Arctic Freezer 7, though they can be had for under £15 if you look around (but that's not inc P&P like OcUK)
Funnily enough I just upgraded from the Arctic 7 to the Xigmatek 1283 this weekend, the AC7 is great for the money but the 1283 is worth the extra cash ;)
That ^ Beats the TRUE in certain situations...
The only time it doesn't is when the TRUE has 2 fans running at a good speed, so making lots of noise. Seriously who can be bothered listening to that racket for the sake of 1-2C?
The Xigmatek is an awesome cooler, especially if you want to run your PC overclocked AND within reasonable quietness :)
Yeah the 1283 is quieter and cools better but it does cost nearly twice as much.
Also the bolt through kit is an absolute must. The push pins are ok on the F7pro but they're almost impossible on the 1283.
