Right, ive just got myself a nzxt vulcan which i quite like other than being a little tight to work with im almost there, had to ditch the h50 as it wont fit without removing the front hdd cage, anyway i got a Zalman CNPS10X today along with the case but i cant fit it either as a push or a push pull setup as the fan would be fowled by my ram, now i could take the drastic action of getting some ram without huge heatsinks but that will just end up costing me more, so what would you recommend, the width of the fan is 74mm (apparantly from specs on here, ive not yet measure it) any idea what is half decent but wont fowl the ramsinks?
I may try that and move it forward to give enough space to install my H50
that way i can install the side 200mm fan and get a lot of air in keeping the top 2 as exhausts
