1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
CPU cooler but no case fans
Discussion in 'Overclocking & Cooling' started by VirginStranger, Jan 26, 2019.
  1. doyll
    Sgarrista
    I'm kinda embarrassed to admit it, but half of my HDDs are external. :o I've found them less expensive and just as dependable. I've been using them for years with no failures or problems. My user storage is on external and backup is on internal, 16GB each. Not sure what your media library will include, but if you plan to keep much video you might want to consider more than 1TB of media storage. 1TB is a drop in the proverbial bucket assuming your videos are mid to upper quality and surround sound.
  2. CageyH
    It is mainly music, so 1Tb is fine for now.
    Films are stored on my HP Microserver, which currently has around 8Tb of storage available.
  3. CageyH
    Two Samsung 860 Evo SSDs are now fitted, and the max CPU temp has jumped to 56 degrees fanless.
    No other changes have been made, so I guess I need to open the vents in my case.
  4. mattyfez
    Sgarrista
    If them max is under 60c that's well well within safe operating temps.
  5. CageyH
    Agreed, but it peaked at 66 degrees last night. That is getting a bit close for comfort.
    I have opened the top rear vent on the case, and I have lost 20 degrees, with it dropping to 46 degrees max.
    I am happy with that.
