I'm looking to get a CM690 case, and need to know the most effective CPU cooler.
On the site, someone has asked if a 155mm HSF will fit, to which they replied that the side fan mounting brackets need to be removed for this to work.
So here comes the question, is it best to have those two fans as intakes (as suggested) and a smaller HSF, or will it be better to ditch those two fans and just have a big chunky HSF?
And can anyone suggest the best that WILL fit with the fans, or the best that fits without the fans? Thermalright U120 Extreme still the best of the best?
