HI, I am running the setup in my sig and to control the cpu cooler i am using the supplied asrock Oc tuner, But i need another prog to do this as the asrock prog keeps going backto default.
I would like to use a prog that i can set up a profile for the cooler to run at certain speeds dependant on temp,Is this possible...
Any ideas on a prog i can use?
Will riva tuner do it?
Thanks James
Thanks James
