if you dont clock you could just use a TRUE passively
i might want to clock a bit
this one says max 24db: http://www.overclockers.co.uk/showproduct.php?prodid=HS-052-AK
is it any good?
Looks like an Arctic Cooling Freezer 7 Pro rip-off, and probably a way off the best coolers, and noisier to cool well.
Thermaltake V1 AX, they just look sweet![]()
Yes and rip-off that has direct heatpipe contact on the base and cools a lot better. Its on par with the Sunbeam Core Contact too.
Apart from the stupid push pin design, this "rip-off" does an exceptionally good job for Core 2's and i7s alike.
Think I'll just stick to water cooling matters!get this cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-SY&groupid=701&catid=57&subcat=821
runs well without a fan with just the case fan after going over a few heatsinks I find it better then the TRUE and ultra bit big tho
