CPU Cooler fit on a gigabyte GA-EX58-UD5
11 Aug 2003
Taunton, Somerset
Did I read some where that if you are filling all 6 RAM slots that a Prolimatech Megahalems with 2 25mm fans wouldn't fit?
If this is the case what cooler would people recommend instead
You certainly can't fit 12gb of RAM in with a Titan Fenrir which is a similar size [I'm using one on my UD5] however if you only use 3 slots its fine.
A TRUE 120 might fit, but i've never used one, so can't be sure....
Something that DEFINITELY will fit would be the Corsair H50 http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-CS
[Currently out of stock its so in demand]
From what i have read it performs as good as the best air coolers, if not slightly better
A Prom Meg+2 fan's will block of 1 ram slot UD5, Corsair H50+2 Apache Fan's(+AC MX-3 Thermal paste) do's not block of any perform's very well, dead easy to fit, less weight for the motherbroad to carry and it's getting very popular with peep's in the forum.OH and l use 1. ;)
The Corsair H50 would be a good bet as it doesnt foul the ram slots and is a pretty darn good cooler to boot.
OK so I'm kind of getting the impression that all the big coolers with two fans in push/pull aren't going to work on a gigabyte GA-EX58-UD5 with 12 GB RAM.
As I see it I either change my motherboard (suggestions always welcome) or I go for a corsair h50.
The H50 with two fans how is that fitted, do you use an extra wire clip or screws or what??
