fenderbass86 said:You need to use a bit of force. It has the same fittings as the stock heatsink, and I had a bit of a hard time fitting it to my old Pentium 4. When you've pushed it in, you should turn the four locks in the direction the arrows on it indicate.
gam3r said:I thought that would loosen the Hsf? turning it the opposite way the arrows point would tighten it? or is the gigabyte manual wrong
