CPU Cooler for a MATX board
14 May 2009
Hampshire
Hello,
I have a Asus H81M-K board with both RAM slots being used.
I'm looking at getting a new CPU cooler but worried that the cooler might not fit.
What CPU cooler would give me the best RAM clearance?
Would it be best to go for an ITX based cooler?
I quite like the CM Hyper 412S
Case: in win 503
CPU: i5 4670 (non k)
Thanks.
We need to know what ram you have first.
I have a matx board but have low profile ram and can fit the dark rock Pro 3 no problem :)
NH-U14S is also very wide .. 150mm if memory serves meaning it's 75mm from center of base toward PCIe socket. ;)
True Spirit 140 rev. A cools just as well, is less money and 69mm center base toward PCIe socket.
yep definitely very wide! depends on the motherboard if you'll have any issues. Sounds like the true spirit would be better in this scenario then!
So I broke my motherboard last night so had to buy a new one!
Ended up getting a better motherboard (MSI H97 GAMING 3) so I should now be able to fit any CPU cooler in it!
ah. sorry to hear about the broken mobo.
Make sure you check how tall the cooler you get is and that it will be compatible with your case!
