28 Feb 2010 at 13:10 #1 zabul zabul Associate Joined 22 May 2007 Posts 29 Hi as above can someone reccomend an cpu cooler for my q6600 socket 775. mobo is a asus p5qpl.regards
28 Feb 2010 at 13:15 #2 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,080 Location Dundee are you going to overclock it? also what case will you be using ?
28 Feb 2010 at 15:23 #3 zabul zabul Associate OP Joined 22 May 2007 Posts 29 htpc cpu cooler hi yes the case is a Lian Li PC-C37B.and no overclocking will be done.
28 Feb 2010 at 15:39 #4 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,080 Location Dundee one of these should fit and be more than enough to cool a stock q6600 - http://www.overclockers.co.uk/showproduct.php?prodid=HS-022-ZA&groupid=701&catid=57&subcat=1395 there is a review of it here - http://www.frostytech.com/articleview.cfm?articleID=1991
28 Feb 2010 at 15:43 #5 IKMS IKMS Associate Joined 21 Feb 2010 Posts 531 Location South Wales So you need a cooler even though you aren't overclocking? How are you possibly getting super high temps without overclocking?
28 Feb 2010 at 15:49 #6 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,080 Location Dundee he probably just wants something quieter than the stock cooler i guess.
28 Feb 2010 at 15:51 #7 IKMS IKMS Associate Joined 21 Feb 2010 Posts 531 Location South Wales chipps101 said: he probably just wants something quieter than the stock cooler i guess. Click to expand... Break the fan blades off and just have the centerpiece spinning, ought to stop the noise. Or you could get a different fan I suppose...
