Hi,
Looking to overclock my i7-3770K so after a good CPU cooler that will work with my current hardware:
- i7-3770K
- Gigabyte UD5H http://www.gigabyte.com/products/product-page.aspx?pid=4440#ov
- Patriot Venom RAM http://www.overclockers.co.uk/showproduct.php?prodid=MY-086-PA
- Corsair Carbide 500R http://www.overclockers.co.uk/showproduct.php?prodid=CA-057-CS
The machine is used primarily for motion/video work, so needs a good cooler for long renders and demanding use. As quiet as possible, but low temps is priority. Budget is not an issue at this stage.
The main thing I'm worried about is the high profile Patriot Venom RAM getting in the way.
Any advice appreciated. Thanks!
- i7-3770K
said or remove heat spreaders from RAM as nkata said and use most any cooler made. True Spirit 140 is very good cooler and very cheap... even cheaper on special right now. £26.39 is so cheap I'm tempted to get on just to have on hand... and I already have Macho HE-02, Ultra 120A, Cogage Arrow, PH-TC14PE and Zaward Vapor 120 waiting to be used.
