CPU Cooler Help
25 Dec 2009
Hi,
I have just built a new PC using the following:
ASUS Sabertooth 990FX Motherboard
AMD FX-8120 Processor
4GB (2x2GB) G.Skill RipjawsX DDR3 1600MHz CL7
Artic Cooling Freezer 13
When I went to install the RAM I noticed that I couldn't use slot 1 due to the heatsink on the ram fouling on the CPU cooler.
Can anyone recommend a good CPU cooler for the same price as the Freezer 13 that will allow me to use RAM slot 1. Or is there a way of still being able to use the Freezer 13?
Thanks
