CPU Cooler - i5-3570K 3.40GHz, Zalman z9, Asus P8Z77-V LX2 Intel Z77
6 Jan 2013
Rightyho! Below is my abbreviated spec:
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor
Asus P8Z77-V LX2 Intel Z77 (Socket 1155) DDR3 Motherboard
Zalman Z9 Plus Tower Case with Fan Controller
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
I'm looking into overclocking this seems pointless buying this CPU if I havent considered it. Ideally there is someone who has this MOBO and CPU and knows a cooler that'll fit without affecting Kingston HyperX RAM.
Like the looks of Titan, Sapphire, Zalman coolers but practicality, quietness and cost as always are priority.
What sort of OC should I beable to expect... I also have:
HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card
What do I ned to OC this?
I have a Asus P8Z77-V LE Plus and Phanteks PH-TC14PE CPU Cooler and i can fit both cpu fans without any problems using Corsair Vengeance memory.
Both fans are always at 600rpm even with the cpu overclocked at 4.5GHz
