- 11 Apr 2011
- Somerset
Hey all, another question!
I've just gone through my case quieting a few fans down with some improvised foam grommets which has helped, but the major culprit as far as noise goes appears to be the CPU fan, which I suppose is to be expected. It's a Corsair A50 cooler that came with the motherboard bundle. Are there any tried and tested ways of quietening it down?
From what I can see, the fan itself should be replaceable, as it looks to be held onto the clip that attaches it to the cooler with rubber stalks. If that's the case, can anyone recommend a quiet but high performance fan to replace the original? I'd rather not go through the debacle of replacing the entire cooler, just the fan.
Only three pins on the fan so no way of controlling it from the computers side.
