Cpu Cooler. Prodigy M. 4670k.
25 Nov 2013
Hi guys.
So, looking for a decent aftermarket cooler for my i5 4670k.
Looking at a mild overclock of 4GHz - 4.2GHz.
Problems i'm having includes using the Prodigy M which seems to have some awkward cooling issues and also the socket placement on my motherboard (MSI Z87i)
Have been looking at the Hyper 212 Evo but cant figure if it will fit?
Also looking at the Corsair H series of AIO coolers.
Any help will be super appreciated.
Mewzikk.
On the prodigy M you cant mount a fan on the front if I'm correct? Just back, top and bottom. AIO intake from back? 2x 120mm intake top and 1x 230mm bottom?
Which AIO is decent and isn't to loud?
Ah no problem. AIO seems the way forward but which one?
If i was choosing, it would have to be the H100. And get some quieter fans than what it comes with, or you could just go for a 120mm aio, the H75 which has come out is good or go for a h80i, which i have. Mine is quiet, however, my case is modded and only accepts 140mm fans beneath my case.
